Throwout Bearing Question
Are these symptoms of a bad throwout bearing, u joint or something else?
Slight rattle from tranny tunnel with car in neutral.
Weird grinding noise from same area when making slow tight turn while in gear and clutch engaged.
Sometimes feels like slack in driveline during shifts.
It's a T56. Flywheel is SLP lightweight steel, pressure plate is lightweight SLP, and clutch disc is Clutchnet Carbon Fiber. I think all have about 2 years and 30-40k miles on them.
Re: Throwout Bearing Question
Honestly, that sounds like normal LT-1 clutch noise to me.
Since mine was new, it rattled when idling, and did the grinding/rattle when starting from a stop. It has ~ 90K miles now and everything is fine.... well, except the engine is being put in now..but nothing to do with the clutch.
-Dave C. '97 Z28
-Dave C. '97 Z28
LOL. Glad to know, but this doesn't sound normal, and it kinda pops (jumps) when it does it and it's a nasty grinding noise that wasn't there before when I make hard, slow turns.
-Dave C. '97 Z28
PS: If you could somehow post a sound clip of it it might be easier to diagnose.
I cut the wheel in an empty parking lot and let it go in circles, with my door open, and I swear it sounded more like the middle of the car than the back. One more thing it does is when I'm slowing down, there's a weird vibration at like 5 MPH whether I'm on the brakes or not.
Also, I know it's not a broken tooth because it doesn't do it in a straight line. (It better not be a broken tooth on a 12 bolt.)
Sergio
Jan 27, 2016 04:27 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
