Those w/ Aftermarket Auto Shifters
Old Nov 21, 2003 | 06:53 PM
aram's Avatar
I'm installing a B&M Pro Ratchet shifter and everything is going great, figured out the Neutral Safety switch and reverse lights, just had a couple questions:
The NSS wiring is 10 ga and the microswitches don't seem like they can handle the current draw from something that needs that big wiring .. did you guys install a relay for the NSS wires or just hook em up to the microswitch?
What does the little coil part that has a small plug going into it at the front (closest to firewall) of the stock auto shifter do? I unplugged it but don't know if it's important.
Anyone have any pics of there installs? I'm gonna just mount mine w/o a console for now and later maybe try to use my old 98 console with a few precision cuts.
Old Nov 21, 2003 | 08:02 PM
96z's Avatar
96z
Wow, not too many guys have pulled off a clean auto shifter swap. If you are talking about the wire running to the steering column(it runs partly by the firewall) that prevents you from starting your car in gear.
PROJECT X
Apr 17, 2015 12:13 AM
Apr 16, 2015 09:57 AM
mattstrike
Mar 11, 2015 07:33 PM
tds1213
Nov 27, 2014 12:55 PM
