Best Shift Point?
Old Nov 20, 2003 | 09:32 PM
Teal96TA's Avatar
Best Shift Point?
How can you tell from a dyno graph what the best shift point would be for your car?
Old Nov 21, 2003 | 05:17 AM
rskrause's Avatar
Moderator
It's easier to show it grahically than to explain it. You want maximum area under the torque curve. By superimposing the torque curves in each gear, shift points can be easily estimated visually. Look at http://wahiduddin.net/race/dynotest.htm to see what I mean.
Rich Krause
Old Nov 21, 2003 | 07:06 PM
Teal96TA's Avatar
Ok, I'm with you so far I think, but you don't want to do it too soon or you end up too low in the RPM's right? Which means you have to go past the peak x amount. How do you determine the value of x?
Old Nov 21, 2003 | 09:51 PM
rskrause's Avatar
Moderator
One method is to make a graph like the one in the link. Then you simply shift at the rpm represented by where the lines cross.
Rich Krause
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
number77
Sep 6, 2002 01:29 PM
96z
Sep 5, 2002 07:53 PM
