Th400__vss__fast
Old Dec 12, 2003 | 07:25 PM
LJ93Z28GM's Avatar
Th400__vss__fast
Have a TH400 trans on order for a 95 camaro with a Bank to Bank Fast system.
I am wondering what programs I am going to run into programming wise. I did not do the tune. Will anything change since it is a manual car??
Car sees about 8.5 pounds from the ATI, was told by the trans builder that I cannot use a standard valve body but have to go with a forward manual or reverse manual since it is vaccum operated for shifts. Is this completely true.
Trying to maintain the stock speedo what VSS parts are needed. What compaines make a plug and play box or is it esy enough to use parts from the 4L80E
Sorry if vague on any of the questions since it is not my car. More info if needed.
TIA
Old Dec 13, 2003 | 11:50 PM
You should probably post this on the "Drivetrain..." forum. The subject of TH400 conversions and the VSS interface has been covered many times. Not sure what tuning issues you would run into - what interface would the FAST have with the tranny?
Moving to "Drivetrain...."
Old Dec 16, 2003 | 03:09 PM
mongse_1's Avatar
GM parts #s for the sensor and the ring are in this thread:
http://web.camaross.com/forums/showt...ight=TH400+VSS
