TH400 VSS Sensor Install ?
Old Nov 30, 2003 | 07:19 PM
JodyJ's Avatar
Well today I tried to install the VSS rotor and sensor, but ran into a few problems. I pulled out the tail shaft housing and saw this.
http://jody.dltechnologies.com/th400-c.jpg
http://jody.dltechnologies.com/th400-b.jpg
http://jody.dltechnologies.com/th400-a.jpg
Do I replace the original parts with the vss rotor and sensor? Also, I slipped on the vss rotor on the tail shaft and it slides in and out with no resistance.
Any help will be greatly appreciated.
Thanks,
Jody J.
Old Dec 2, 2003 | 08:20 PM
JodyJ's Avatar
TTT - Anybody?
Old Dec 3, 2003 | 07:49 AM
Brady's Avatar
You've go to get the stock speedometer stuff out of there. You're on the right track. I think the tailshaft is a little bigger where the reluctor goes, I had to heat mine in boiling water and tap it on. The speed pickup goes in right where your second picture is.
good luck!
Old Dec 3, 2003 | 10:48 AM
JodyJ's Avatar
Thanks for the reply Brady. How long did you have to boil it?
Jody J.
Old Dec 3, 2003 | 11:21 PM
Brady's Avatar
Jody J.
until it was hot
Old Dec 28, 2010 | 05:00 PM
chief455's Avatar
Re: TH400 VSS Sensor Install ?
I searched deep for this!
Can anyone post follow up pics or at least detail.
my guess:
Pull the tailhousing off.
remove the speedo gear parts from the case and the drive gear from the tailshaft
install the VSS 40 tooth reluctor onto the tailshaft
install the VSS sensor through exsisting hole in case
install tail housing
is that right?
Old Dec 28, 2010 | 05:55 PM
Here's a pic of the 4L60 version:
http://www.jagsthatrun.com/Pages/Gif...rRingReloc.gif
Old Dec 28, 2010 | 06:37 PM
chief455's Avatar
Originally Posted by Injuneer
thanks Fred - I saw that pic from your previous post - I think I can handle it
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
