th400 Blowbroof bellhousing, on a 96 Z,lt1
Im planning on doing a th400 or 350 tranny swap this winter. At one of my stops today,tranny dhop, a guy was showing me a blowproof bellhousing for the 400 trannys. I noticed that it was quite a bit thicker than the stock bellhousing, Is anyone running one of these? Will it clear the tunnel and can I still get the bolts in the bellhousing without much "massaging". I figures this would be the time do do this beings how Im not going to run a midplate, if that is even possable. Thanks
If its the JW Ultra Bell, it fits fine. As I recall, there was some machine work done to the bell to match the TH400 case I had. But I had a shop do the install, with the trans.
Yeah I realize that, But this bellhousing had mounting holes accomidated for both. The guy at the tranny shop said that some cut the 2 pontiac ears off beings how they stuck up another 1 inch from the housing and could cause clearance issues. But je also said that it will sometimes cause you trouble with the sfi certification. But Im sure if I go with one Ill find a brand that is not a multi application housing
