TH350 in a Turbo'd LT1. What Fluid?
I've read "do NOT use Synthetics" and recommendations to use Dextron III ATF but that's always been in the context of the 4L60E's it appears. What fluid should be used in the TH350?
Thanks,
Dave
Thanks,
Dave
actually the use of synthetics is highly recommended. i use royal purple max ATF in my th400 ~900hp bbc camaro. the key is the anti wear additives they add, especially good in manual valve body situations where front pump seals take a beating and wear. not to mention the friciton modifiers they add to keep things from slipping, similar to ford type F fluid. i ran type F in my gm trannies before i switched to synthetic. ive noticed a noticeable reduction in wear for sure.
Formula Steve
Sep 19, 2023 08:31 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
