Th350 Swap
Iam am in the process of doing the same swap, I know Iam going with the BMR crossmember and matching tourqe arm. also I went with the manual valve body so there is no kick-down cable. Iam still not sure about the flexplate though??? hope this helped a lil
I did this swap a few months back in my car...love it!!
The honest truth is though, if you dont yank the wheels now you wont with a TH350 either. The gearing in the 60e (assuming thats what you have) is better for launching than whats in the TH350. However the TH350 is alot easier to get to hold the power.
I had to change:
TH350 Trans - get the long tailshaft version so you can re-use the driveshaft
TH350 Convertor
TA - went with Chassis mounted TA
Crossmember - went with an aftermarket tubular style - some guys fab the stock crossmember
B&M Ratchet shifter - some rig the stock shifter to work
Was able to reuse the TCI flexplate I had
Used the stock A4 console, no problem
No retune needed or done
Think thats about it...cost about $1200 total for the swap. Check ls1tech, there is a great write up on it in the transmission section.
I had to change:
TH350 Convertor
To each thier own though.
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
