TH350 speedo
Old Sep 18, 2004 | 10:21 AM
SMOKNZ's Avatar
TH350 speedo
Just wondering if anyone has been able to getthe TH350 to work with our speedo's. I know the TH400 will with the ring and reluctor from GM, but will these same parts work in a TH350, or are there different parts that will.
Bill
Old Sep 18, 2004 | 12:02 PM
rskrause's Avatar
Moderator
Re: TH350 speedo
Bill
Yes, the regular GM parts will work but you have to reprogram the PCM to give a correct gauge reading. LT1_Edit does not allow access to the relevant tables, but Tunercat does. So if you are OBDI, you should be set. If it's OBD2, then I can't say how it might work.
BTW: if you are willing to go without OD, why not a TH400? I know it's heavier and has a bit more rotating mass, but it is stronger. If it's not a hi-po car, the TH350 should be fine, but in that case why not stick with an OD tranny?
Rich
Old Sep 30, 2004 | 08:29 PM
SMOKNZ's Avatar
Re: TH350 speedo
I got the whole setup for pretty cheap. We will see how it lasts. If it doesn't I still have the shifter converter crossmember and tranny cooler and lines for the TH400.
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
LazyLemming
Aug 29, 2015 07:36 PM
4586
Aug 24, 2015 11:04 PM
