TH350 speedo
Just wondering if anyone has been able to getthe TH350 to work with our speedo's. I know the TH400 will with the ring and reluctor from GM, but will these same parts work in a TH350, or are there different parts that will.
Thanks Bill |
Re: TH350 speedo
Thanks Bill BTW: if you are willing to go without OD, why not a TH400? I know it's heavier and has a bit more rotating mass, but it is stronger. If it's not a hi-po car, the TH350 should be fine, but in that case why not stick with an OD tranny? Rich |
Re: TH350 speedo
I got the whole setup for pretty cheap. We will see how it lasts. If it doesn't I still have the shifter converter crossmember and tranny cooler and lines for the TH400.
