TCC problem
Old Sep 13, 2006 | 07:32 PM
CamaroKid89RS's Avatar
TCC problem
On my '94 the torque converter hasn't locked up since I've had it. I took pin 11 on the blug plug that ran to the lockup solenoid and wired in a switch, one side to the solenoid, the other to ground. It didn't work, I tried ign power instead of ground because I wasn't sure if that was supposed to be used instead of ground, nothing. Does that mean my solenoid is bad? I have no codes that I know of.
Old Sep 15, 2006 | 05:21 PM
Re: TCC problem
The car used to be a 5 speed and now it's an automatic. Do I need a different switch for tcc lockup, because I have it wired into the brake light switch right now?
Old Sep 17, 2006 | 01:40 PM
Re: TCC problem
Dropped the pan and found out the solenoid is ok. Got voltage on Pin 11 when ign is on, and when I ground Pin 11 the solenoid engages. I checked voltage when I get up to speed and when the computer should ground the signal, and I get about .6V. I think it's supposed to be 0, and .6 is pretty close, but I don't know if that much of a difference would make the thing not work.
Old Sep 19, 2006 | 10:54 PM
Re: TCC problem
When I get up to highway speed I get 8.2 Mega ohms, should this number be lower? Could I possibly have a bad ground?
Old Sep 26, 2006 | 09:09 PM
Digital Designs's Avatar
Re: TCC problem
make sure you have the correct year and correct wire in the transmission "activated".... a 94 4l60e is much different than a 95 or newer tranny.... a 95' has a Pulse Width Modulated TCC solenoid.
Old Sep 28, 2006 | 09:35 AM
Re: TCC problem
I have checked with the transmission pan off, it sounds like the solenoid works fine, counted the wires, 12, (95 had 13) and the Pcm Vin the year code shows a 94. I checked the ground, seemed ok, maybe thinking perhaps bad flash. I'm waiting until I get a laptop battery so I can hook up and get a little better look at what the PCM says.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
z28projects4ever
133
Jul 26, 2002 01:54 AM
