T-56 Tranny Problem !!!! Please Help
Old Aug 17, 2005 | 12:17 PM
SLP1999CamaroSS's Avatar
Hi i need help when i am drivin or even jus sittin in the car with it runnin and clutch in my shifter gets real tight and i can get it in gears and move it but its really tight then it will get normal again but it keeps gettin tight probably once every 10 minutes. does anyone kno what could be wrong i can still get it in gears jus real tough fluids are good ?? Please Help me even with car off and shiftin it still gets tight and loosens back up to normal
Old Aug 18, 2005 | 06:54 PM
Loony's Avatar
Re: T-56 Tranny Problem !!!! Please Help
Have you bled the system? You might have air in there...
Old Aug 19, 2005 | 11:41 PM
Cincymaro88's Avatar
Im gettin the same problem on a new clutch install. Espically when im in first its like at times i need 2 people to push the shifter in gear, other times, the thing just slides right in.
Justin
Old Aug 21, 2005 | 09:18 AM
Dtimekw's Avatar
Hate to say it, but me too. I can push the clutch in and out once and the problem goes away, until the next stop light. It is not just 1st gear. When the tranny is "acting" up, it happens in all the gears. I changed the trans fluid. It went away for about three tanks of gas (50miles LOL). I am now hearing clunking noises at idle in neutral with clutch out. Noise goes away when clutch is in. If I find anything, I'll post. Good luck.
Old Aug 21, 2005 | 09:27 AM
akafred's Avatar
your hydrolic system ethier leaks or as air in it check you clutch fluid resivoir... i have had the sam problem on 3 cars, every time the slave cylender leaked!!!!!
jmadoll
May 27, 2015 07:13 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
