T-56 potential problem? please help!
Old Jan 30, 2011 | 07:16 PM
kaden0307's Avatar
Post T-56 potential problem? please help!
Hello. I am relatively new to being a z28 owner but someone please help. I just bought a 94 z28 5.7 6spd manual trans. 117k miles. Here's my problem. Shifting from 1st to 2nd at a lower rpm is shifting from 1st to 4th. But shifting from 1st to 2nd at a higher rpm shifts into 2nd normally. All other gears work fine. I was told that its a common prob with my typw of z28 and that a simple "$75 wire harness" is all that neaded to bypass this stock problem. Is this true? Can someone please tell me what's going on if this is true or not. Or should I worry... thank you
Jim
Old Jan 30, 2011 | 07:29 PM
transAMdriv3r's Avatar
Re: T-56 potential problem? please help!
yeah it has a skip shift feature and yes that harness will bypass it
Old Jan 30, 2011 | 07:40 PM
kaden0307's Avatar
Post Re: T-56 potential problem? please help!
In reguards to the harness that bypasses the "skip shift" feature. How much do they generally run for? And what are they called exactly?
Old Jan 31, 2011 | 08:37 AM
RUDEDOG's Avatar
Do a search on skip shift. You can do it much cheaper. All you need is a resistor. 2.2 k if I recall correctly.
Old Jan 31, 2011 | 08:42 AM
kaden0307's Avatar
Thanks man.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
james007moore
Jan 1, 2016 01:14 PM
Duke
Jul 31, 2002 05:13 PM
