T-56 Hard to Put in Gear
Old Jan 26, 2006 | 12:50 PM
Deenasty's Avatar
Hey guys, my t-56 lately has been kind of hard to put into gear. This problem is intermediate, and its not all gears, usually 1 and 6th. The fluid has been flushed regularly and I have been using Royal purple Synchromax. Any suggestions?
Old Jan 26, 2006 | 11:18 PM
96camaroSS's Avatar
Re: T-56 Hard to Put in Gear
That's a new combination to me. It's usually 1st and reverse that can be a pain. At least mine was after the "wonderful" Centerforce DF install. I see you list a custom clutch. Can you be more specific about what you have?
PS. I have a personal theory on why the Centerforce causes hard shifts. I'll be happy to share if anyone asks.
Old Jan 26, 2006 | 11:19 PM
Deenasty's Avatar
i made a mistake, yes its 1st and reverse. Its a stock pressure plate, with a custom disc. I have had a spec and a centerforce in the past, and this setup hooks up harder, is less chatterful on the street, and was a third of the price...
Old Jan 27, 2006 | 08:48 PM
96camaroSS's Avatar
I don't know what to suggest. I've had this problem too. But I know mine is caused by the centerforce pressure plate. Mine gets hard to get into those two gears after I've shifted at high rpm a couple of times. Strangely enough, it corrects itself if it sits for a day or two before I drive it again. I wish I knew something to suggest. Maybe someone else with more t-56 knowledge can step in.
Old Jan 29, 2006 | 12:56 AM
JonZ28SS's Avatar
I'd like to know your theory on the Centerforce clutch. I have a DF clutch and like it, although I have noticed after a few runs it does need a "cool down" time before it hooks the same.
Old Jan 29, 2006 | 04:03 AM
Bayer-Z28's Avatar
Hmm... Same here. I'm in the market for a new clutch and PP. Still doing research.
The twin disk centerforce?? Mebie the rough engaugement is due to heat expansion?? -Disk wise. More rotating weight takes longer to slow down?
Old Jan 29, 2006 | 08:59 AM
cehan's Avatar
What I've heard about the Centerforce is that the added clamping pressure afforded by the flyweights on the springs causes extra load on the hydraulics when you go to shift at high RPM, and eventually causes premature master or slave cylinder cylinder failure.
Old Jan 29, 2006 | 09:15 PM
96camaroSS's Avatar
You asked...so here goes.(please keep in mind it is only MY theory)
As someone else said. I absolutely believe it has to do with the centrifugal weights. I think at high rpm's this causes the slave/master cylinder to incorrectly adjust itself. It's supposed to self-adjust to compensate for clutch wear. But, it also seems to be forced out of correct adjustment after a hard run. It will seemingly "slip" back to right after a day or two of rest, and shift very easily until the next time I run it hard again.
Old Jan 29, 2006 | 09:48 PM
Deenasty's Avatar
ok, well I dont have a centerforce clutch, anymore suggestions?
Old Jan 30, 2006 | 11:28 AM
silentsprintero's Avatar
sorry still going on centerforce, but i've never had any problems shifting in
1st or reverse? even after hard launches it seems to hook up fine and go into all gears fine
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
edxiel
Jan 24, 2015 07:40 PM
