Swap in a 4 channel rear in a 3 channel car
I am wanting to swap in a 4 channel rear that I have access too. Is there a way to keep the ABS working correctly? I read that you can extend the wires to one of the wheel sensors. Is that correct? Thanks in advance
Re: Swap in a 4 channel rear in a 3 channel car
As someone suggested in another thread that you posted in, try it. Logically, the pulse count per tire rev difference between the huge 3-channel reluctor gear on the carrier is going to be significantly different than the pulse count from the tiny 4-channel reluctor on the ends of the axles.
I've seen a reluctor and pickup added to the pinion shaft (for other purposes than ABS). Might want to try that appraoch.
http://www.injuneer.com/images/photo.../DCP03821a.jpg
On the other hand, this post says it worked for him:
https://www.camaroz28.com/forums/sho...47&postcount=6
Unfortunately, that member hasn't been active on the site since last October, but you could try an e-mail.
