Super T10 question
Old Apr 14, 2008 | 12:26 PM
TB2's Avatar
TB2
Super T10 question
I've got a line on a trans for my Bird. How much power can I put through a Super T10 trans? And how well do they hold up to abuse?
Old Apr 14, 2008 | 12:34 PM
From an article in Chevy High Performance
The Borg Warner T-10 cast-iron case four-speed was introduced in 1957. Until late 1963, T-10s had a cast-iron housing, 10-spline input, and 16-spline output-shaft with an overall length of 21.5 inches and 14 inches from case to mount. These boxes disappeared from Chevrolet production cars until its triumphant return in 1974. Renamed the Super T-10, or Second Design, the new trans featured a 22.25-inch overall case length and kept the 14-inch trans mount location but switched to an aluminum case. The splines followed Muncie’s lead and picked up the 26/32 input/output shaft configurations.
The Super T-10 has a Borg-Warner stamp and all factory Super T-10s have aluminum main cases. The T-10 will need a 16-spline slip-yolk to work in the Chevelle; the overall dimensions are that of the pre-’71 M20 and M21, and the pre-’70 M22. The Super T-10 needs a 32-spline output shaft to work; it has the same dimensions as the ’71-and-later M20 and M21, and the ’70-and-later M22.
Richmond Gear also offers an updated version of the Super T-10 four-speed; it weighs in at a slight 70 pounds, will tolerate up to 375 ft-lbs of torque, and has an overall length of 22.61. If this trans is used as a replacement for the Powerglide, a 32-spline yolk will have to be used and the driveshaft will have to be shortened 1-½ inches. The Richmond uses the same 14-inch mount location.
http://www.chevyhiperformance.com/te...ech/index.html
Old Apr 15, 2008 | 04:42 AM
Pro Built Automatics's Avatar
Back in the mid 1970's and through the early 1980's we had them in mid ten second through high eleven second vehicles with very little breakage. Most of these were "power shifted". We mostly used the cast iron cases and the aluminum cases in Fords. We used the 2.64 and 2.43 first gear setups, and were used exclusively, they had the best clash rate. They were easy to build, and parts were much cheaper in the those days. The way we got them to live was always use a clutch that had marcel (wave washer) in it. This makes for a smoother engagement, and is much easier on the whole drivetrain. We would use a modified diaphram clutch, in most instances. This type of clutch when used is much easier to make a power shift. Depending on the WOT shift rpm, we would modify the sliders and syncros to get the cleanest shifts. Cryoing of the gears and case was almost always done. So yes, I think they would hold up to some horsepower.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
lt1matt
Mar 21, 2015 07:35 PM
rcajun86
Jan 30, 2015 01:56 PM
NewsBot
Jan 8, 2015 11:29 PM
