strengthening 10 bolt
Old Feb 3, 2006 | 06:44 PM
nb 96 z's Avatar
Does a rear end girdle really strengthen up your rear end? Like the T/A rear end girdle, is it worth the money? Or should I just wait and buy a 12 bolt when the 10 bolt breaks? Thanks
Old Feb 3, 2006 | 08:39 PM
96camaroSS's Avatar
Re: strengthening 10 bolt
It'll help prevent flexing of the case and bearing caps. Stepping up to a 12 bolt or 9 inch is a better route if you plan on hitting the rear end with much more power than stock. If you don't want or need to spend the money on a stronger rear end at least spend the money on the girdle. It's a cost effective way to strengthen your stock rear end to a point.
FWIW My car has the aluminum rear end cover(no bearing cap bracing)that was installed by SLP and I've hit it with way more than it was intended to see. It's a 6 speed and I've used every tire short of drag slicks without blowing it up. I'm not going to push my luck by trying slicks though. Pretty sure I know how that story will end!
Old Feb 4, 2006 | 08:53 AM
wrd1972's Avatar
Werd
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
squarehead
Nov 21, 2014 08:02 PM
