Strange 12bolt
Old Dec 21, 2005 | 08:32 PM
chevy94c's Avatar
Strange 12bolt
I am about to install a stange 12 bolt rear. Whatelse am i going to need to do this? I have the driveshaft from the car the 12 bolt came from.
Old Dec 22, 2005 | 04:02 AM
Cmr0z28's Avatar
Re: Strange 12bolt
You shouldn't need anything
Just swap your brakes on assuming the rear doesn't come with brakes...and I can't think of anything else. Make sure you have at least an inch of back and forth play in the driveshaft before you bolt it in, and if the rear isn't full, you'll need about 2.5-2.75 qts of fluid and a bottle of GM LSD additive if it has the Eaton posi.
Old Dec 22, 2005 | 07:02 AM
Re: Strange 12bolt
Its fairly straight forward, but I do have an online install procedure:
http://members.aol.com/InjuneerZZ/Strange12.htm
Old Dec 23, 2005 | 10:15 PM
chevy94c's Avatar
Re: Strange 12bolt
Thanks guys for your help
Old Dec 24, 2005 | 02:13 AM
CreatiVe2's Avatar
Re: Strange 12bolt
hey i did the literally the other day... the only thing i needed were new bushings (old ones broke) and the Rear comes with a U-joint replacement, you might need a shop to press it in your driveshaft, for the 3" aluminum, it would be easier just 2 clips, the 2.5" steel needs to have the plastic nubs melted all the way through to release the u joint, 10-15$ at a shop. overall the install wasnt that bad, the 12 bolt was definatly heavier. lol...
Old Dec 25, 2005 | 09:52 AM
chevy94c's Avatar
Re: Strange 12bolt
Thanks CreatiVe2
I might try to get it in at work as soon as i pick it up.
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
tdigger9899
Sep 7, 2015 10:56 AM
KYWes
Aug 10, 2015 07:03 PM
