stock rear end
Its a GM 10-bolt, 7.5/7.625" (all 4th Gens)
It has a limited slip differential (RPO code G80 - standard with all V8 models, optional on V6 models).
Gear ratios for 94-02:
Automatics came with either 2.73 (RPO GU2 - standard on V8 models), or 3.23 (RPO GU5 - "performance rear axle" option) gears.
6-speed standards came with 3.42 gears.
Standard is a 3-channel ABS system (one sensor on top of differential center section) and optional with Traction Control (RPO NW9) is a 4-channel system with a sensor on the brake backing plate on each side.
Standard on all V8 models with disc brakes. Drum brakes on V6 models, with an option for discs.
oldschool
Feb 9, 2016 09:21 PM
