Stock gearing for 2002 Z-28
Old May 16, 2006 | 10:59 AM
NASCR46's Avatar
What is the stock gearing for a 2002 Z-28 with an automatic Transmission?Thanks!
Old May 16, 2006 | 11:12 AM
2001NBMZ28's Avatar
Re: Stock gearing for 2002 Z-28
Either 2.73 (GU2) or 3.23 (GU5).
Old May 16, 2006 | 12:09 PM
1SlowFormula's Avatar
A vert with the power in your sig running the times in your sig, I guess 2.73's, check you RPO codes like stated above...
Old May 17, 2006 | 10:13 AM
NASCR46's Avatar
Thanks,I checked the codes. GU5 3:23 Just wondering why the times would indicate The gearing?
Old May 17, 2006 | 10:20 AM
A bad guess, I'd say...
I am making a little less power then you, and you are trapping higher but at about the same ET, and I accounted that to the weight difference of the vert, that's all...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
spearous
Jan 12, 2015 11:03 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
