Steel driveshaft handle what 60ft times?
I have upgraded just about everything to handle a great 60ft time except my steel driveshaft. I do have an M6 that will be getting a better clutch. My question is at what 60ft times do you think I will be pushing my driveshaft to it's limits? Thanks for any help.
The Stock steely is damn strong, and stronger than the stock aluminum shaft by quite a bit.
If yours runs true and doesn't vibrate it should be good for your car from your description with a LOT of room to spare.
If you WANT to upgrade; which at your HP levels I wouldn't unless you break yours or yours vibrates like a ****; then the "Best"/"Strongest" one out there is the Denny's Nitrous Ready shaft.
Richardan15
May 30, 2015 08:36 AM
