startin to hate my m6
Old Sep 16, 2007 | 06:31 PM
edunegan95's Avatar
im not pleased with my m6 it broke about a year ago and i had everything replaced that was broke with aftermarket upgraded stuff from a great place ! now i was enjoying my driving experience this evening when i go to 3rd i heard a little grind no big deal right we've all heard it before but now every time i shift into 3rd it does the little grind.its the syncro right? its not hesitant to go goes right in and stays in but that little grind is really annoying after spending that much money on it ! so my question is is the t56 a weak trans? can it handle mid 400hp abuse everyday or should i swap in auto?ive got a great auto guy 45 min from my home my manual guy is 9hr one way from my home!thanks for any info/feedback!!!!!
Old Sep 17, 2007 | 07:30 AM
95Blackhawk's Avatar
Mine has 80K on it with no problems. You could have a bad one. Honestly, I have heard nothing but good things about this tranny.
Old Sep 21, 2007 | 04:16 PM
thesource2004's Avatar
The T56 is a bad azz transmission but you need to keep your clutch in good working shape along with using a good after market shifter like the Pro 5.0 .
Old Sep 21, 2007 | 04:44 PM
edunegan95's Avatar
i have the pro 5.0 shifter w/ bump stops!
Old Sep 21, 2007 | 05:44 PM
wrd1972's Avatar
M6 awesome tranny, cluth design leaves a lot to be desired compared to other applications..
Old Sep 21, 2007 | 11:41 PM
Dragoneye's Avatar
Forgetting the clutch itself, though...how much power are the gearboxes known to handle? And how many miles are they known to have on them(just the gearbox), before failing?
Old Sep 22, 2007 | 01:36 PM
metallicsniper's Avatar
i believe the stock T56 can handle 400-450 foot pounds of torque of daily abuse
Old Sep 23, 2007 | 09:25 PM
RedWS6TA's Avatar
these trannys are fairly tough. what is wrong with yours is the syncro blocker ring is worn out. the syncro blocker rings job is to slow down the gear so that it will not grind going into gear. when it wears out you get the grinding noise you are referring to. did the guy that rebuilt the tranny replace all of the blocker rings or just the ones that were bad at the time? with the right parts a t56 can handle a lot of abuse
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
WPHIG2
Aug 27, 2015 06:37 AM
FieroLT1
Jun 26, 2015 08:43 PM
jackpawt883
May 20, 2015 06:53 AM
4586
Jan 3, 2015 07:22 PM
