stall and daily driving?
Old May 14, 2004 | 02:11 PM
  #16
ppmz28's Avatar
here is a question to go along w/ the subject... is there a stall that is only activated when I manually pull the car into first gear???? so that when I am in OD it drives normal??? Probably a stupid question but I was just wondering..
Old May 14, 2004 | 02:54 PM
  #17
krispy's Avatar
negative ghost rider
Old May 14, 2004 | 02:57 PM
  #18
acslinger2525's Avatar
the pattern is full
Old May 14, 2004 | 07:39 PM
  #19
96capricemgr's Avatar
At cruise the TC should lock up so it does't matter.
Old May 14, 2004 | 08:25 PM
  #20
ARTIC_Z's Avatar
my car has a 3000 stall and i didnt like it at first but now im use to it. the only thing i dont like is all the vibration.
Old May 14, 2004 | 10:21 PM
  #21
TCI is not a good converter I would say the vibration is either exessive hub runnout or out of balance(maybe both), either way I would prepare for it to damage the tranny. I briefly ran a Level 10 TC blew the tranny which I believe was unrelated, but when I gave the TC to someone else to have it cleaned from the tranny debris they found the hub runnout to be .10"(not a typo) and it to be badly out of balance drivability sucked as well, it had TCI internals and an Art Carr serial. It was such a raging piece of crap I cut my loses and went to a higher yet stall Edge and things were much smoother and it drives better even with my 4500lbs beast couldn't be happier. After that I will never do buisiness with Level 10, TCI or Art Carr since that one piece was so bad and linked to all 3.
Wether you think TCI is a good company or not a high stall TC should not cause vibration address the problem soon.
Old May 15, 2004 | 08:34 AM
  #22
Eff's Avatar
Eff
i got a yank SY3500 and it takes alittle getting used to. virtually no idle and before i think i only went to about 1800 rpms in 1st to slowly exelerate through an intersection now i have to go to about 2800-3000 not good if there is a cop next to you. In the highway the onlything you will notice with a high stall is a small jolt when the TCC locks up. but the 3500 RPM launch makes it all worth it!
Old May 15, 2004 | 11:57 AM
  #23
I have a 3300 vig, and i dont have any vibration, its smooth as can be.
Old May 16, 2004 | 11:55 AM
  #24
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
my 12" 2500 is almost like the stocker unless i push hard on the pedal. they both start moving the car as soon as i push on the pedal. the difference is in flooring it. the 2500 jumps to 2500 / 3000 and rips the rear end loose. the stock just ramped up normally. it should cause no extra vibration. the vibration means something is out of balance or not right.
david
Old May 19, 2004 | 02:02 PM
  #25
86 redbird's Avatar
another related question. I had a 2800 stall in my firebird (350 turbo) although I have 3.73 gears, it was still crusing through town under stall speed. How does this effect the transmission? My tranny is shot now, and I just wondered if this had anything to do with it?
Old May 21, 2004 | 07:52 AM
  #26
dren70's Avatar
IMHO since you were below stall the fluid is spinning inside the TC and heating up. if you didn't have a cooler to keep the fluid temps down you may have had issues with overheating. other than a temperature related issue i dont think you should have had any problem.
david
Old May 21, 2004 | 12:45 PM
  #27
86 redbird's Avatar
I do have a tranny cooler. Seems like this problem would be even worse with a 700 because of the low cruise speeds in OD.
Feffman
Oct 9, 2015 05:42 AM
dbrockma
Feb 16, 2015 02:56 PM
nophix
Nov 30, 2014 10:26 PM
Snoman73
Nov 17, 2014 07:22 PM
ced8
Jun 24, 2002 11:11 AM
