Which stage should i get???
Old Sep 17, 2003 | 04:24 PM
CamaroZ28LT1's Avatar
Ok my stock clutch just went out on my 1997 6sp camaro i want to get a spec clutch but should i get the stage 2 or stage 3????? my car has no mods yet but in time i plan on putting on some, but if i was to go ahead and get the stage 3 would it hurt anything being only stock gears and trans, i plan on getting a spech flywheel also? so i know that i really dont need the spec 3 clutch right now but i dont want to get the spec 2 and then after about 2 years when i deside to upgrade my car going back to put a stage 3 in. help me
thanks josh
Old Sep 17, 2003 | 11:59 PM
AL SS590 M6's Avatar
Moderator
a stage 3 is over kill but I can't see where it would hurt any thing.
Old Sep 18, 2003 | 12:11 AM
m0nk's Avatar
It all depends on how much you want to spend, and how far you plan on modding your car. Also try to remember that the higher stage you go, the comfertable drivability of the car goes down. My old spec stage 3 chattered a bit, but that was the older style, mine also broke :/ Me I dont care about drivability as I have solid engine and a poly trans mount. My car is defiantly drivable, as a dayly driver for me, but the chatter in the new street twin bothers some people, and the vibrations from the car in idle due to the sold mounts scare others. I love it thou
Old Sep 18, 2003 | 12:49 PM
So do u think i should just go with the spec 2 clutch with the alum. flywheel? id that a good setup. and if i really wanted to put it in myself is it possible my friend knows alot about z28s and he also has a lift. IS there anywhere i can get a step by step digrapham or pictures? thanks alot
Josh
Old Sep 18, 2003 | 09:44 PM
InjectedSS's Avatar
yea i'm a big fan of the stage 3 but dude if you don't even have any mods now, i would go with the stage 2.. i don't think you would like the 3 since you don't really have a lot of torque to tame it...
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
karpetcm
Aug 14, 2015 03:02 PM
Henson071
Aug 4, 2015 09:32 AM
Boss002
Jul 9, 2015 03:33 PM
