Spohn torque arm set-up
Old Apr 4, 2009 | 09:30 AM
stephenpen's Avatar
I just installed a spohn body mount torque arm and I have no idea how to set it up properly. If anyone could point me in the right direction I would appreciate it. Its on a lt1 m6 with a stock 10 bolt.
Old Apr 4, 2009 | 01:20 PM
It comes with a level to check the pinion angle. Did you try using that? You want at least 1-deg with a stockish engine, up to 2-deg with higher HP. When measuring the angle of the DS and the angle of the pinion shaft, you need to end up with a "\/" pointing down.
Old Apr 4, 2009 | 02:21 PM
stephenpen's Avatar
I bought it second hand and it did not come with the protractor. I'm going to pick one up now.
thanks
Old Apr 4, 2009 | 10:02 PM
You can get a small digital level from Sears for about $29. It's a lot easier to use than the gravity protractor.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
