Spec Stage II means I need new master & slave cylinder?
Old Aug 20, 2003 | 01:38 PM
therealmagyver's Avatar
Question Spec Stage II means I need new master & slave cylinder?
Getting a spec stage II at this point until someone shows me a better option at a comparable price. I want to know if I need to get new slave and master cylinders.
Old Aug 20, 2003 | 02:37 PM
reuter's Avatar
not for the lt1 at least. stage 2 = very nice its got some bite to it but really isnt much more aggressive than the stocker.
Old Aug 20, 2003 | 03:19 PM
It holds up to 530lbs of torque. When I spray I'm at about 400 or less, so stage II is more than enough. Getting a mild cam and long tubes and I will still be under the 500 mark.
Old Aug 20, 2003 | 10:56 PM
AL SS590 M6's Avatar
Moderator
The newer hydraulics are a LOT better than the 98s. The SPEC kit comes with a new slave so you just need to get a new style GM master or a McCloud adjustable master.
Old Aug 21, 2003 | 12:55 AM
Thanks for the slave info. With the 02 master slave will I need to do the drill mod?
Old Aug 21, 2003 | 04:22 AM
Moderator
Yes. It's an easy thing to do and free. So why not?
Old Aug 21, 2003 | 09:01 AM
Will do then. I didn't know if they removed the restriction on the newer master cylinder.
sherwinZ28
Jun 6, 2015 08:48 PM
supercharged94Z28
Jun 2, 2015 03:32 PM
Rod Bender
May 16, 2015 02:16 PM
R@mpage
Apr 20, 2015 10:02 AM
