Slipping tranny
Old Jan 27, 2007 | 06:01 PM
chris8835's Avatar
Slipping tranny
Hello,
I have a 95 Z28 with almost 50,000 miles on it as of now, and ive noticed now when I go WOT the tranny will occasionally slip from 1-2 and almost always slips from 2-3. I do race the car every once and while but other than that I drive it normal on the streets and it shifts fine then,the slipping only occurs during WOT.The tranny feels nowhere how it used to now,could this tranny be on it's way out? Im going to change the fluids soon and see if that helps, but if not what could I be looking at here? Any comments would help alot.
Old Jan 27, 2007 | 06:08 PM
Pete Kane's Avatar
If the fluid level is correct, and the filter is not blocked, you likely have a dying trans
Old Jan 27, 2007 | 06:16 PM
Performabuilt's Avatar
Supporting Vendor
drop pan plan to change fliud and filter , If less that a tea spoon of material in pan proceed and change the PCS also (presure control solenoid)If you change this PM me , if there is more than a tea spoon and or if its metalic then just put in new filter and drive easy and order a new trans . SEE SIG
Hope this helps any questions just PM, Yahoo IM (performabuilt )or call number in sig
Old Jan 27, 2007 | 07:39 PM
12SCNDZ's Avatar
The stock 4L60E suffers from several pressure and holding power short comings that contribute to what you're feeling. This is often a common complaint that we hear before we build a performance transmission. We have PROVEN ways to fix them. Do some research before you settle on a transmission builder, if you feel it's time for a rebuild. Check the backround of whoever you have build it for you. If you choose a builder from this board, you might want to do a search and check with their past customers (if you can find any).
If you check out our backround, you'll find many satisfied customers with 12, 11, 10, and even 9 second 4L60E's. We offer a 4L60E that will take whatever you want to throw at it for $1400.
Please feel free to call me if you'd like to discuss anything further. 302-250-1202
If you're curious about our work, click the link below and then click on "CPT CARS".
Thanks,
Frank
CPT
Old Jan 27, 2007 | 08:22 PM
Supporting Vendor
True research and ask questions but considering the mileage I would do the fluid and PCS change first there may yet be alot of miles left in there yet with such low mileage the PCS is a likely culprit particularly if this condition came on suddenly
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
