slave cylinder ?
Old May 29, 2004 | 08:56 AM
INSANEZ's Avatar
slave cylinder ?
How do you "bleed" a slave cylinder. Do you just fill the resevoir and slowly pump the pedal? I just finished a t56 swap so I new to this stuff. Thanks for any help.
Old May 29, 2004 | 06:14 PM
OBE1 95Z28's Avatar
The master/slave module comes from GM pre-filled with fluid so it shouldn't need to be bled. If you think it needs bleeding, disconnect the slave from the bell housing and slowly pump the piston in and out. You can have a buddy pop the lid off the reservoir and watch for bubbles. You might want to wrap a rag around the reservoir in cause the fluid decides to splash.
Old May 29, 2004 | 06:59 PM
INSANEZ's Avatar
I will try that
The reason I think it needs bled is that it was a t56 swap and it came open so fluid leaked out.
thanks again
Steve
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
