shifting problem
Old Jun 2, 2007 | 05:38 PM
red 95 z28 lt1's Avatar
shifting problem
car was running fine untill i had the converter loosened up to aprox 3600 stall then i was running into problems with the computer and stall wall issue, sent out the pcm to get that fixed, now when i manually shift it, the car will bounce the limiter in first still after i shift into 2nd. and i shifted at 6200 rpm the limiter is set at 6800 rpm, but if i let it shift by its self it shifts fine,
what could be the problem
i also lost converter lockup
Old Jun 2, 2007 | 06:28 PM
Performabuilt's Avatar
Supporting Vendor
Do you happen to know what the WOT shift points are set at in the tune.
Old Jun 2, 2007 | 08:56 PM
12SCNDZ's Avatar
It might be time to send that transmission to us. This is really starting to sound like internal transmission issues.
Frank
CPT
Old Jun 2, 2007 | 09:57 PM
Supporting Vendor
Frank
CPT
I wonder where he did get it from a PRO RACE 4L65E 1995 model? Does not sound like yours or ours.
Old Jun 3, 2007 | 03:24 PM
hold on, absolutly no problems shifting before i had the converter restalled, all they did was loosen up the converter and change fluid and filter(which i do once a year)
i want to say that they are set at 5800 when its in drive, it shifts fine in drive,
now today when i manually shifted to second at 6200rpm it shifted every time,
Old Jun 3, 2007 | 06:31 PM
Supporting Vendor
You need to spend some time with tuning , Sounds like theres some issue there, Stalls can be confusing for the PCM
Old Jun 3, 2007 | 11:52 PM
well im going to eastside performance soon to have them dynotune my car
ill have them look into that
thanks for all the help and ill keep everyone updated
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
jb4xx
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
