Shift Too Early?
Old Aug 1, 2008 | 06:25 PM
JakeDub's Avatar
Shift Too Early?
just bought a '93 lt1 with a shift kit, and it seems to shift early into 2nd, shifts hard at about 1500, basically right after i accel, the rest of the gears seem to shift out as usual. is this normal and if not what can i do?
Old Aug 1, 2008 | 06:55 PM
Pro Built Automatics's Avatar
Make sure that the TV cable is adjusted correctly. The TV cable should be tight at WOT, or a 1/16" (one click) of play at the most. Do this first and see what happens. Do you know which valve body kit is installed?
Old Aug 1, 2008 | 08:19 PM
JakeDub's Avatar
any help pin pointing the tv cable? is that the one with the teeth? you just pull it all the way back or what?
Old Aug 2, 2008 | 04:32 PM
JakeDub's Avatar
alright, found the tv cable and its all good now, thanks much
Old Aug 2, 2008 | 05:21 PM
Did this solve the problem?
Old Aug 2, 2008 | 08:35 PM
JakeDub's Avatar
yes it did as far as I'm concerned, it shifts 1-2 at about 18-20mph and at higher rpms, instead of immediately. Thanks a lot man.
Formula Steve
Sep 19, 2023 08:31 AM
marlar98
Sep 19, 2015 07:53 AM
CARiD
Sep 7, 2015 08:21 AM
Pwilson59
Sep 3, 2015 08:47 PM
War Engine
Aug 21, 2015 05:28 AM
