Shift Too Early?
Shift Too Early?
just bought a '93 lt1 with a shift kit, and it seems to shift early into 2nd, shifts hard at about 1500, basically right after i accel, the rest of the gears seem to shift out as usual. is this normal and if not what can i do?
Make sure that the TV cable is adjusted correctly. The TV cable should be tight at WOT, or a 1/16" (one click) of play at the most. Do this first and see what happens. Do you know which valve body kit is installed?
Formula Steve
Sep 19, 2023 08:31 AM
CARiD
Sep 7, 2015 08:21 AM
