Setting Pinion Angle
Old Jul 27, 2006 | 07:58 AM
  #16
Jason Lauzon's Avatar
Re: Setting Pinion Angle
Yes, if you draw a line from the tranny output to the pinion input it would be down 4 deg from horizontal except, the height from the ground to the tranny and from the ground to the pinion is not the same. The tranny is obviously higher up off of the ground than the pinion output. Wouldn't that have an effect on things?
I have tried dropping the nose of the pinion a degree or two from there and and makes the vibration a little worse. I think that is actually where I have it set right now.
I have a sketch drawn up in auto-cad but I don't know how to attach it. Is there a way to attach an image or PDF?
[IMG]C:\Documents and Settings\jlauzon\My Documents[/IMG]
Old Jul 27, 2006 | 09:10 AM
  #17
Dave '97 Z28 M6's Avatar
Upload it here: http://imageshack.us/
They'll give you an URL that you can put in the IMG tags.
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
kev93z28
Aug 19, 2002 12:48 AM
Brady
Jul 29, 2002 10:30 PM
