Serpentine Belt Tensioner Assembly for 1LE
Old Jan 31, 2020 | 01:05 PM
1994-LT1-Eric's Avatar
Hi all,
Anyone seen a serpentine belt tensioner assembly w/pulley like this? If so, know where I can get a replacement?
I have an 1LE with an aftermarket air conditioner so this may be different than what is customarily stock, and doesn't look like what I have in the factory service manual.
Worse case, I find a replacement pulley that will install on that bracket, then adjust the tension manually since there is no indicator mark on my tensioner system.
I replaced the serpentine belt and think it was too tight, cause the edge of it got rubbed a bit. Then this pulley started chirping.
Old Jan 31, 2020 | 01:11 PM
Re: Serpentine Belt Tensioner Assembly for 1LE
From the service manual.
Old Jan 31, 2020 | 01:21 PM
What they show as the GM part, new from Hawk's Motorsports:
Old Jan 31, 2020 | 04:27 PM
I found out that the factory tensioner assembly don't fit because my after market compressor housing won't allow the component to bolt in.
So ima have to go find a pulley just like this to get rid of that chirping bearing.
Hector95Z28
Aug 10, 2010 11:25 PM
siguy
Apr 22, 2010 06:29 PM
ssonoma
Mar 12, 2006 10:44 AM
1st and goal
Mar 1, 2004 09:25 AM
