Seal between Shifter and Trans?
Old Aug 10, 2006 | 10:27 PM
Jazsun's Avatar
Do you put a bead of RTV or silicon between the trans top and the shifter? Or is it not requiered?
Also If possible I would like to re-use the rubber boot which screws into the frame of the car to keep water out and what not. It looks like I only need to trim the top of it to fit my new hurst comp plus. Is this a good idea or not?
Do People just not use the rubber boot w/ aftermarket shifters?
Old Aug 11, 2006 | 09:21 AM
Jazsun's Avatar
Re: Seal between Shifter and Trans?
anyone? Kinda need to find out quick, since everything is waiting on this.
Old Aug 11, 2006 | 10:37 AM
Capn Pete's Avatar
I think you have to seal the shifter on there somehow (gasket, sealant) because oil does flow through there. How much "flow" is it really? I dunno. But regardless, I think it's gotta get sealed up somehow (although I'm sorta new to the 6-speed world, so we really need an "expert's" advice on this one!)
... and as for the boot? Well, again, I'm not sure about what most guys do, but I'd be inclined to cut out the boot to fit how you need, but don't remove it completely.
Old Aug 11, 2006 | 12:20 PM
FireChicken1995's Avatar
put a moderate beam of RTV and call it a day. i put RTV on mine when i put my ripper in and have not yet had a leak from it. as far as the boot im sure you are talking about the way the hole is cut in the top of the boot its like a "D" hole just force that over the shifter or even cut the hole to make it a perfect "O" so it slides down the shaft all nice and pretty its all up to you but i would use it if i were you hope you like the shifter later
james007moore
Jan 1, 2016 01:14 PM
PCLZ28
Dec 24, 2015 05:19 PM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
