Screwed up rearend, Whats wrong?
Old Feb 18, 2006 | 12:39 AM
99_Z_155's Avatar
ok, heres what happens, when i turn sharp, the car jumps and makes clunking noises. when i give it the gas, only one tire spins. so i know there is something wrong, like the positrack is screwed, or an axle is jacked up. is there any way to tell, and can i still drive the car? it drives just fine in a straight line with no noises, but i dont know if that makes a difference.
Thanks for any advice.
J
Old Feb 18, 2006 | 07:27 AM
Re: Screwed up rearend, Whats wrong?
When you step on the throttle in a turn, the posi locks the 2 axles together. Since you are turning a corner, you don't want the axles locked together, since the inside wheel needs to turn slower than the outside wheel. If they lock up, as they will do with a correctly functioning posi - under hard load - the inside wheel has got to slip going aroung the corner.
Doesn't sound like there is anything wrong at all, except the posi is a little on the aggressive side. Does it have the GM LSD additive in it?
Old Feb 18, 2006 | 07:39 AM
30696bird's Avatar
I have a broke worm gear in mine. When I'm in reverse it pops and jumps. It will get worse pretty quick if it's affecting forward movement.
Old Feb 18, 2006 | 01:33 PM
99_Z_155's Avatar
well, it messes up durring turns, but im talking the one tire breaks lose just in a straight shot under a load, so im thinking the posi is not working at all. if the worm gear was broken, then i would think it wouldnt even drive right at all.
Thanks for the replies.
Old Feb 18, 2006 | 04:03 PM
99_Z_155's Avatar
Anyone else have a clue???
Formula Steve
Sep 19, 2023 08:31 AM
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
