screw on the throttle body
Adjusting the throttle has nothing to do with the speedo.
Your speedo is off for one of two reasons, 1-if you have white face guages then the needle was put on wrong. 2-If you or someone else did any programming to the pcm, the tire/gear setting are wrong because of the rear gearing or tire size.
