Rpms with 3500 stall
Old Sep 6, 2004 | 07:10 PM
JS99Z's Avatar
I have a TCI SSF 3500 converter in my 99 Z28. I don't think the converter is locking up. With 3.23 gears what rpms should the car be at in overdrive at 75mph. Right now when I'm at 75mph my rpms are at about 2300. I think they should be at 2000 or less in overdrive. When this converter locks up should it be at the same rpms as the factory converter? Is there some kind of chart or something that would tell me what rpm I should be at when I'm going a certain speed when the converter is locked? Also if the converter is not locking is there a way to tell if the converter itself is the problem or something in the PCM.
Old Sep 6, 2004 | 11:06 PM
Need4Camaro's Avatar
Re: Rpms with 3500 stall
I'm not sure but 2300 sounds close to right for me... 75 MPH isn't remarkably slow of a speed and most cars I've driven do 75 at 3000 RPM's. My dad's Z28 did 70 MPH at 2k RPMS so I really don't see a problem at all.
Old Sep 7, 2004 | 06:45 AM
2001NBMZ28's Avatar
At 2300 RPM you should be running 78 MPH in OD www.f-body.org/gears/
The TC should lock up around 40 MPH and unlock a couple MPH below that letting off the gas, or if you touch the brake.
Xiantyl
Jul 21, 2015 05:42 AM
asilomar244
Jul 12, 2015 05:53 AM
birdblack
Jul 8, 2015 07:23 AM
z28cam1993
Jun 23, 2015 09:14 PM
Viper
Jul 30, 2002 02:06 AM
