Ring and Pinion gear replacement
Ouch- that's pretty steep- even if you replaced all the bearings, pinion, axle, carrier- any other parts replaced? Axles? Carrier? I am sure they nickle and dimed you on the gasket, oil, posi additive, but, sheesh, that is a lot - prolly could have found a salvage yard axle for a couple hundred dollars-
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Feb 1, 2015 08:26 AM
