Reverse grinds. Slave or master bad? New clutch
Old Mar 27, 2008 | 01:06 AM
LT1BanditTA95's Avatar
My internet just started workin again.. I think my bud my have made a threadalready.. But we just put in a ram powergrip clutch set in my TA... now the one I removed was a cheapy below oem from auto store and was bad. I put the powergrip in and no the pressure plate has way more pressure... MOST of the time when shiftin into Reverse; Reverse grinds... All I can think of is that the master or slave cylinder has gone bad...Hydraulics was already bled and it seems that when I pump the clutch it helps? Any body have an idea before I rip out the cylinders tm? Thanks
Old Mar 28, 2008 | 06:05 PM
billymac49's Avatar
sounds like you have air in the hydraulics or poss. a weak master or slave. how did you bleed it?
Rod Bender
May 16, 2015 02:16 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
