Removing the rear end.. Im stuck
Old Nov 2, 2007 | 09:04 AM
Projectcam94's Avatar
Post Removing the rear end.. Im stuck
Its almost off .. I just need to remove LCAs and the track bar/panhard rod. Bolts on the track bar are TIGHT ive broken like 3 sockets on it and they are getting loose.. Im using a breaker bar and other ways to get them loose?
Or should I just get my grinder out?
Old Nov 2, 2007 | 09:21 AM
00ls100's Avatar
have you tried spraying PB blaster on the bolts yet?? try it and let it soak for a few if you haven't.
Old Nov 2, 2007 | 09:51 AM
Nop I have just with wd 40 ..
Old Nov 2, 2007 | 09:59 AM
97FormulaWS-6's Avatar
WD40 is not a penetrating oil; get some PB blaster or Seafoam Deep-Creep; then let it soak
Old Nov 2, 2007 | 10:36 AM
FivePoint7z28's Avatar
PB BLASTER! That stuff works wonders. Then maybe try an impact to loosen them up or something. then a nice breaker bar. I would be very suprised if pb blaster could not help you. Good luck
Old Nov 2, 2007 | 11:45 AM
Ok im going to try both i got some seafoam deep creep layin around and ill buy some pb after that ill let you all know what happens
Old Nov 2, 2007 | 06:45 PM
wrd1972's Avatar
Get some 1/2 impact sockets. You wont bust those and yes use the PB blaster. Grinder as last resort.
Old Nov 2, 2007 | 06:53 PM
I don't know what you are using for sockets, but a quality 6 point socket should not break.
Old Nov 2, 2007 | 07:10 PM
wrd1972's Avatar
Sounds like some cheap Chinese tools.
Old Nov 2, 2007 | 11:58 PM
Green96Z's Avatar
Didn't even need PB blaster to drop my panhard rod, just used a ratched and box end. Go with some decent Craftsman tools, can't beat that lifetime warranty .
Old Nov 3, 2007 | 09:28 AM
billk1's Avatar
It might be too late but sounds like your bolts are binding up on spuk, you should to wire brush the remaining threads as well as possible them spray some lube on them , try to tighten up a little, brush then lube and untighten Good luck, I use these little cheap wire brushes that look like tooth brushes, get them at auto part stores and use solvent on threads
Old Nov 3, 2007 | 07:52 PM
I got it off finally!! I went and bought my self some craftsman sockets and they didnt brake but the bolt did.. Lol so i took out my grinder and got it off with out messing up any parts.. Actually the new differential is on already . Everything is almost bolted up i just need to buy some rotors and brakepads tomorrow since the ones i had are pretty bad..
Thanks for the help with your responses
Old Nov 4, 2007 | 10:49 AM
"spuk"?????
Old Nov 4, 2007 | 01:40 PM
Ok the rear end is a bolted up i got a couple of questions though .
1. It looks like the thread from bolt that goes on the lower part of the shock. (the one that bolts it on to the differential) is bad.. Where can i buy these type of bolts? Or do i have to buy the whole shock?
2nd The trackbar stayed on the old differential and it wont budge to get it out.. These should be cheap at a junk yard right?
3rd im going to have to have my pcm reprogrammed to the new gears right?
Thats about it Thanks
Old Nov 4, 2007 | 02:18 PM
billk1's Avatar
Originally Posted by Injuneer
"spuk"?????
stuff that grows onto threads thats aided by rust and all sorts of undescribable goop. and thats just for starts
