Removing the rear end.. Im stuck
Its almost off .. I just need to remove LCAs and the track bar/panhard rod. Bolts on the track bar are TIGHT ive broken like 3 sockets on it and they are getting loose.. Im using a breaker bar and other ways to get them loose?
Or should I just get my grinder out?
It might be too late but sounds like your bolts are binding up on spuk, you should to wire brush the remaining threads as well as possible them spray some lube on them , try to tighten up a little, brush then lube and untighten Good luck, I use these little cheap wire brushes that look like tooth brushes, get them at auto part stores and use solvent on threads
I got it off finally!! I went and bought my self some craftsman sockets and they didnt brake but the bolt did.. Lol so i took out my grinder and got it off with out messing up any parts.. Actually the new differential is on already . Everything is almost bolted up i just need to buy some rotors and brakepads tomorrow since the ones i had are pretty bad..
Thanks for the help with your responses
Ok the rear end is a bolted up i got a couple of questions though .
1. It looks like the thread from bolt that goes on the lower part of the shock. (the one that bolts it on to the differential) is bad.. Where can i buy these type of bolts? Or do i have to buy the whole shock?
2nd The trackbar stayed on the old differential and it wont budge to get it out.. These should be cheap at a junk yard right?
3rd im going to have to have my pcm reprogrammed to the new gears right?
Thats about it Thanks
