Removing bell housing! Help
Ok so I took out all the small bolts on the bottom and all the big 14mm bolts I see there are two more bolts which are smaller and kinda inset in the bellhousing. One on each side 3/4 of the way up between a couple of the big 14mm. These bolt seem to be a redish color and indented farther.
Are they bolts that need to be removed or are they some kind of dolls?
Re: Removing bell housing! Help
Originally Posted by Jazsun
come on I need to know for tonight
Edit: inspection plate should be removed of course
I just used a ujoint and got all the bolts easy. But there are two more on the sides which are indented in the housing. Are there dolls holding the housing on? I have all 6 14mms already.
once u get the six bolts out of the bellhousing, use a hammer or screw driver to seperate it fromt he block. I assume you took the actual transmission out first. It's a heck of a lot easier that way. There are 8 bolts holding the tranny to the bellhousing.
What? I had to bump that **** 3 times. Not to mention the other topics in drivetrain forum which just sink to neverland afte 1 day and no replies. Or you just get 200 views and no replies.
NewsBot
May 18, 2015 03:40 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
