rearend swap
Old Aug 22, 2009 | 08:35 PM
mrick123's Avatar
rearend swap
hey guy my stock rearend broke the gears,and i short on cash so my friends crashed his same year 1995 camaro z28 but, i have a a4 and his is a six speed. can i use the rearend out of m6 and use it in my a4??? i know the ratio would be differnt but could it work to keep my car on the road untill i can save some money for a strange 12 blot with tru trac????
Old Aug 23, 2009 | 07:42 AM
AL SS590 M6's Avatar
Moderator
It'll bolt in but the ABS might not work and the speedo WILL be incorrect unless you get the computer programmed for the new ratio. You will love the improved performance.
Old Aug 23, 2009 | 08:53 AM
As long as they are both non-TCS or both TCS, the ABS will work fine. You will need the computer reprogrammed for the gears or your A4 will not shift correctly (aside from the speedometer error).
Old Aug 24, 2009 | 04:02 PM
mrick123's Avatar
what r the stock ratio in the mr rearend??? i think my a4 is 3:23.. but i swap out for 3:73 and had it reprogrammed for the gear swap. yeah i'll just do the mail in tune cuz i dnt have the link cable or software yet(working on it)! need to find out if the other car as the trac control cuz mine does. thanks guys!!
Old Aug 24, 2009 | 07:46 PM
rngilliland's Avatar
The stock ratio for the M6 is 3.42.
If your axles are good you should be able to use a non traction control rear by
using your axles, brake backing plates and any other parts that are different.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
