Rear whining...
Old Sep 13, 2006 | 10:52 PM
supermj's Avatar
Rear whining...
Ok, at speed with foot on gas, there is a pretty good whine. If you let off the gas, the whine goes away. A4 tranny in a 02 z. Any thoughts?
Old Sep 21, 2006 | 08:29 PM
98blckz28's Avatar
Re: Rear whining...
same problem with mine. Guess where mine is now. In the shop getting all new bearings in the rear. But I am also getting a 3.73 installed so I am pretty happy . But you may want to get that checked out asap.
Old Sep 22, 2006 | 05:52 AM
01Z's Avatar
01Z
Re: Rear whining...
If the sound is coming from the rear axle then it could be the way the ring and pinion have been set. The pinion depth and back lash have to be done correctly to set up a quiet differential. This is done with a crushed sleeve and side shims. It is then checked with marking paste for pattern.
If this sound has just now started without any work having been done to the car then this is probably not the reason. Welcome to the forum.
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
