rear ends
Old 09-08-2008, 08:58 AM
c20704's Avatar
rear ends
Will a gen 3 rear fit into a gen 4 camaro?
1986 z-28 to 97 3.8 camaro
Thanks c20704
c20704 is offline
Old 09-08-2008, 03:19 PM
redneckgames's Avatar
I know that the 4th will bolt into a 3rd.
Why are you going 3rd into 4th? Why not get a LSD, disk rear from a 4th?
redneckgames is offline
Old 09-08-2008, 06:36 PM
They will interchange, using the same brackets for the springs, shocks, panhard rod, torque arm, LCA's, etc. The rear brakes will likely be different.
The big difference is that the 3rd Gen rear axle assembly is 3-4" narrower than the 4th Gen rear, so you need to use different wheel offsets, or thick (1.5") adapters to run 4th Gen wheels on a 4th Gen chassis, with a 3rd Gen rear axle assembly.
Injuneer is offline
Old 09-09-2008, 06:11 AM
c20704's Avatar
Thanks for the information, there is a gen 3 rear that I can get for free.
C20704
c20704 is offline
Old 09-09-2008, 08:16 AM
is it a disk or drum rear?
Old 09-09-2008, 01:56 PM
c20704's Avatar
Both are drum brakes
C20704
c20704 is offline
10-31-2016 11:09 AM
blac94Z
03-02-2015 06:03 PM
Chet1185
02-04-2015 09:51 PM
jcamaro95lt1
01-24-2015 08:21 AM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
Quick Reply: rear ends
