which rear end w/ cam & spray?
Old Mar 2, 2006 | 11:44 AM
ponykiller z28's Avatar
After i'm cammed and spraying around a 100 shot, i already determined on ls7 or stage 2 spec clutch w/ stock flywheel, but i know i'l be needing an upgraded rear end .... what are you guys running with a modded setup such as this??
thanks
Old Mar 2, 2006 | 12:01 PM
Slowprocess's Avatar
Re: which rear end w/ cam & spray?
thanks
Stick with that stupid tough stock 10 bolt so I can watch the parts fly out of it in my rearview mirror!!! I'd say go with a 12 bolt setup, because you're not going to want to throw the money out for the 9". The 12 bolt will hold up to those mods. Just a 100 shot? You are trying to run with....a skittle?
Old Mar 3, 2006 | 02:04 AM
leave it to my local buddy slow process to jump out of his natural habitat(performancetrucks.net) and come over here and put his 2 cents in
Old Mar 3, 2006 | 03:57 AM
rskrause's Avatar
Moderator
If you do a search you can see various opinions about the GM 12-bolt and the Ford 9", which are the two basic choices. I am running a 12-bolt with Eaton posi.
Rich
Old Mar 3, 2006 | 04:12 AM
89385formula's Avatar
A 12 bolt for you car just makes alot more sense in my opinion. I believe a 9" would be way overkill for that setup, and it will soak up some extra power.
Old Mar 3, 2006 | 04:31 AM
MonkeyBoneSS's Avatar
Depneds on your budget, I would go with a 12 bolt and at last resort a 9 incher! The 12 bolt has proven itself in the F-bodies and will surely take one hell of a beaten before giving up!
Old Mar 3, 2006 | 10:30 AM
Cmr0z28's Avatar
Moser 12-bolt.
oldschool
Feb 9, 2016 09:21 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
