Which rear end- s60, 9in, 12bolt?
Old Sep 16, 2009 | 11:26 PM
onefastmx5's Avatar
After reading hundred of stories about blown 10 bolts, I want to upgrade my rear end sometime in the future. After seeing how expensive it is, I want this rear to last! I'm leaning toward the s60, since it seems to be the beast of the 3. What are its downsides, besides being heavier and losing a little more power to the wheels? The 9in also sounds nice, being able to switch gears easily. The only way i'd buy the 12 bolt, is if I got a good deal on one (i've read of a few breaking). Any opinions welcome, thanks.
James
Old Sep 17, 2009 | 12:16 AM
Klypto's Avatar
i have a strange 12 bolt and love it... cam only so far and holds up fine with 4.10s
Old Sep 17, 2009 | 03:34 PM
97FormulaWS-6's Avatar
S60/12-bolt you can keep the ABS; 9" you have to kinda fab-your-own way if you want to keep it.
S60 IS the strongest of the bunch.
Old Sep 17, 2009 | 08:34 PM
GreenMountain's Avatar
with a 9" you have to get a new drive shaft too because of the pinion angle is lower but i would go with the 9" or 12bolt. everything by moser
Old Sep 17, 2009 | 08:56 PM
Klypto's Avatar
strange is nice also. fit perfectly
Old Sep 17, 2009 | 09:56 PM
You have to with the S60 as well; and most times with the 12-bolt too....
Old Sep 17, 2009 | 10:07 PM
JakeRobb's Avatar
Super Moderator
What are your power goals? Do you plan on going to the strip with slicks?
Old Sep 17, 2009 | 10:54 PM
onefastmx5's Avatar
Car will be street driven for 2 years (Hopefully I can install in a weekend). After that would be like somewhere in the 450-500RWHP range.
Old Sep 18, 2009 | 06:37 AM
JakeRobb's Avatar
Super Moderator
Then go with the 12-bolt. It's the lightest and is more than strong enough to handle that power level.
Old Sep 18, 2009 | 06:39 AM
onefastmx5's Avatar
What about 5k clutch dumps? Probably on drag radials.
Old Sep 18, 2009 | 07:01 AM
JakeRobb's Avatar
Super Moderator
I'm not speaking from personal experience, but yeah, my understanding is that a 12-bolt will handle that. The typical break point is around 700-800 rwhp.
If you want the extra peace of mind anyway, the Dana 60 is only a little bit heavier (25-30 additional pounds, similarly equipped), MUCH stronger, and often a bit less expensive. Just keep in mind that the extra weight is unsprung weight and will have a negative affect on ride/handling, especially on choppy pavement.
Old Sep 18, 2009 | 02:22 PM
onefastmx5's Avatar
Thanks for the info. Where can i find the cheapest price on the s60?
James
Old Sep 18, 2009 | 02:31 PM
97WS6Pilot's Avatar
Do a little research on how the pinion gear is supported in a 9". Then you will know why it is so popular. Dana 60's are known for being noisy after only a few hard launches.
Old Sep 18, 2009 | 09:23 PM
onefastmx5's Avatar
How much more expensive is the 9".
Old Sep 19, 2009 | 06:51 AM
I'm making 800HP/800 lb-ft at the flywheel, with the 300-shot of nitrous. When the engine was originally built, the tranny was a T56 with a Street Twin/steel flywheel. The Strange 12-bolt had no problem with 5,000-6,000rpm clutch dumps (no spray on launch). But I didn't race it much.
The people who have 12-bolt problems are the ones who run the car every week at the track, a dozen or so passes, with the big clutch dumps. If that's what you plan to use the car for, consider the 60 or the 9-inch.
