Rear end Question
Old Dec 3, 2004 | 10:47 AM
383TransAm's Avatar
Question Rear end Question
I'm looking in to getting some Nittos in the spring and doing a gear swap.
I would like to put in 4.10 gears with a M-6 and Nittos, am I asking for trouble with the 4.10's?
I have 3.23's right now!
I was also thinking of a rear end cover with the end cap screws in it and I would have the stock axels.
Good, Bad or Ugly?
Old Dec 3, 2004 | 11:40 AM
93LT1355's Avatar
Re: Rear end Question
You shouldn't have any trouble at all running 4.10's with a M6.
Old Dec 3, 2004 | 11:59 AM
1BAD86Z's Avatar
Good, Bad or Ugly?
i have a whole rear ready to go, 4.10's studed, ta cover custom solid pinion spacer and a like new auburn, all bearings and seals are new. $ asking 550.00 and can deliver in MI. also either abs systems will work on it.
Old Dec 3, 2004 | 05:27 PM
383TransAm's Avatar
Is that a stock Rear??
Old Dec 4, 2004 | 12:00 AM
1BAD86Z's Avatar
yup, moded to hell, you aint going to find one any stronger.
Old Dec 4, 2004 | 02:03 AM
zx1216's Avatar
crap, i would be all over that this spring
Old Dec 4, 2004 | 04:16 AM
AL SS590 M6's Avatar
Moderator
Good, Bad or Ugly?
Just make sure that you never hook up tight. Keep enough air in the Nittos so that they will spin and you'll be OK. If it hooks hard the torque of your motor will destroy any 10 bolt including your 3.23s.
Old Dec 4, 2004 | 07:42 AM
rskrause's Avatar
Moderator
It's not a yes or no kind of answer. A stock rear with sticky tires will probably not break the first time out. It may last for years. Or something in between. Very hard to predict what any given person's experience will be. But some of the variables are: how sticky are the tires, how sticky is the surface, how much hp you are putting through, and how it is driven.
Rich
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
