Rear end gears?
Old Nov 18, 2010 | 05:28 PM
elis94camaro's Avatar
Rear end gears?
I have the chance at buying a good rear end from a 1997 camaro z28 since my camaro has the 2.73. I wanted to know what gears were 1997 camaro z28s coming out of the factory with so I could upgrade from my 273s? Its an automatic car if that helps
Old Nov 18, 2010 | 07:51 PM
97Z28Muscle's Avatar
Re: Rear end gears?
I believe 3:73 was the stock gear in your '97.
Old Nov 18, 2010 | 08:25 PM
bw_hunter's Avatar
Re: Rear end gears?
3.23 for automatics, 3.42 for manuals
Some a4's might have 2.73's
None came stock with 3.73
Old Nov 18, 2010 | 10:22 PM
Re: Rear end gears?
The Z28 with an A4 trans could have either 2.73 (base model) or 3.23 (performance rear axle option) gears. M6 had the 3.42's, as mentioned above. And as Bruce pointed out, there was no 4th Gen that left the factory with a 3.73 rear axle.
Assuming from your screen name (elis94camaro) that you have a 94, you have a rear axle assembly with a single sensor for 3-channel ABS. The 95-97 cars have either the single sensor 3-channel ABS setup, or a two sensor 4-channel ABS + ASR (aka TCS - traction control). You have to be sure the wheel sensor system in the 97 rear axle assembly matches your 94.
If you don't have a 94 (or even if you do), add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. That makes it easier for people to help you.
Old Nov 19, 2010 | 08:12 AM
Re: Rear end gears?
Thanks for telling me ,but how would I know if I have a single sensor 3-channel abs or a two sensor 4 channel?
Old Nov 19, 2010 | 08:34 AM
bw_hunter's Avatar
Re: Rear end gears?
That's pretty easy. The 3 channel systems havea sensor on the center section of teh rear. It's on top and is just a wire going to a sensor. The 4 channel systems have a sensor at each wheel and none on the center section. The wheel sensors will be behind the rear brakes....
Does your car have traction control?
Old Jan 10, 2011 | 10:25 PM
92 camaro's Avatar
Re: Rear end gears?
hi name is tony.first time user.i have a 92 camaro with 3:23 gear.(disc brakes)want to change to 3:73 can anyone tell me if its 2 or 3 carrier set up.thanks
Old Jan 10, 2011 | 10:49 PM
Re: Rear end gears?
A stock 3.23 ratio would have a 3 series carrier.
Old Jan 11, 2011 | 01:48 AM
dodge69874's Avatar
Re: Rear end gears?
x2
I have 3.42's in my bird, and life is good.
Old Jan 11, 2011 | 01:55 AM
RamAir95TA's Avatar
Re: Rear end gears?
Some V6 A4 cars came with 3.42s, if you can believe that.
Old Jan 11, 2011 | 02:17 AM
dodge69874's Avatar
Re: Rear end gears?
My dad's V6 A5 Explorer has factory 3.73 gears. My mom's V8 A4 Crown Vic has factory 3.55 gears. Both have Trac-lock. I have the 3.42's with Posi-trac. Seriously, I love these set ups. Can't imagine what 2.73's with an open differential with be like.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
