rear end
Old Apr 6, 2008 | 11:21 PM
nitrofinch's Avatar
rear end
I was wondering what the weak point are in the rear end of my 1995 z28. I got slicks for it when i go to the track and I am already doing 4.10s hear later this weak. I just want to do everything I can do not to break the rear.
Old Apr 6, 2008 | 11:28 PM
GreasyB's Avatar
Not much you can do with a 7 1/2''. And this belongs in the drivetrain section.
Old Apr 7, 2008 | 12:16 PM
1racerdude's Avatar
4.10's won't last long.
Look at the size of the pinion--- 'bout the ize of an egg--- not enough contact. 3.73 max and it won't last with slicks.
Maybe a little longer with an auto.
3.43 will last far longer.
Old Apr 7, 2008 | 12:18 PM
Javier97Z28's Avatar
Moderator
Moving to drivetrain...
Old Apr 7, 2008 | 03:30 PM
rskrause's Avatar
Moderator
It's going to have a limited life span with sticky tires on a prepped surface, especially with a manny tranny. You should also expect to wear the clutch out pretty quick, especially if you want to save the rear, because the best way to do that is to slip the clutch off the line.
Rich
Old Apr 7, 2008 | 03:48 PM
onebadponcho's Avatar
I'm thinking about the only thing you can do that would guarantee the 10 bolt won't break is to remove it. Hopefully it stays intact on the way out.
Old Apr 7, 2008 | 11:56 PM
nitrofinch's Avatar
Thank you for the info. Could anyone recommend a good 9inch. The only one I have found is from Moser and its $2500
Old Apr 8, 2008 | 07:31 AM
Sending PM.
Old Apr 8, 2008 | 08:33 AM
Have you ruled out a 12-bolt and a Dana 60?
Old Apr 8, 2008 | 03:44 PM
nitrofinch's Avatar
I havent ruled anything out at this point. If possible I would like something thats a dirrect replacment because of the limited resources I have as far as mechanical skill and tools such a welder and so on.
Old Apr 8, 2008 | 03:48 PM
CustomSSI's Avatar
A 9", 12-Bolt or S60 are pretty much "bolt in". The S60 you have to buy a new DS or shorten your stock one. What kind of power are you thinking you will or are currently putting down?
Old Apr 8, 2008 | 04:41 PM
The rear axle assembly swap is pretty easy. A couple hours on jackstands, with minimal tools, no welding. As suggested above, what you need depends on what kind of power you are making. Each of the direct bolt-in replacements has its pluses and minuses.....
Old Apr 8, 2008 | 04:46 PM
nitrofinch's Avatar
I am currently making 384rwhp amd 352rwtq but I am planning on building the bottom end soon
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
